I am interested in buying a PRO 2055, and was under the impression it could be remotely programmed via a PC interface.... that is, set up all the frequencies, tones, alpha tags on a computer then load the data into the radio via the serial link.
I downloaded the PRO 2055 manual, and I don't see any specific discussion of such a capability... I do see "cloning", where data is moved from one scanner to another scanner, but not to and from a PC.
Can someone clarify if a PC can be used. If not how tedious is it to manually enter about 300 freqs, PL tones and alpha tags?
Also, what is the max length of an alpha tag?
