I used a program psr edit-300 to download the Texas Wide Area Radio Network (TxWARN) Motorola
Motorola Type II SmartZone directly into the scanner from radio reference.com. The scanner does not stop on anything while scanning. I am using an indoor antenna that came with the scanner. I am about 1 mile from the system.
CJCTXS,
You're trying to monitor the analog version of TxWARN, which is this one:
Texas Wide Area Radio Network (TxWARN) Motorola Trunking System, Metro Houston area, Texas - Scanner Frequencies
You have not specified your location, nor which site you're trying to monitor, but if
any of the frequencies for the site you are trying to import and monitor have something other than a
5 in the fourth decimal place, then your Pro-2055 will not work. To monitor those sites correctly, you must also load the custom band plan for rebanded systems. While PSREdit300 may show them in place, your Pro-2055 cannot be programmed with the band plan. It's firmware, unlike that of the successor model Pro163, could not be updated to support updated systems.
For more on rebanding, see this
article in the Wiki. To monitor this system, you will need a rebanding capable scanner. While there are a number to choose from, the eventual migration of users from the
analog TxWARN to the digital
system suggests that perhaps an upgrade to a digital scanner, rather than another analog, would be a better move.
