Hmmm,... Also make sure that the Lock Out Box is clicked in the not locked out position... OK pick a UCAN site/cell closest to you....
Load it in an empty bank (any but 9,... and start in chan 01, not 00 just to be on the safe side....) Set to CLOSED Mode. Set the bank to MO, set each of the chan slots that you load to MO. Program in every one of the freqs for that site/cell. Set the delay to OFF on every slot....
Go over to the Talkgroups slots.....
Program in the TG's you want to hear.
Now put the scanner into scan and let it acquire the CC for the UCAN TRS. If your close eneough to the cell/site, your scanner will then decode the CC and start trunking.
Remember that there are a few things that effect trunk tracking: Distance from the transmitter is the biggest.
Proper programming of your scanner.
The type of antenna set up you have.
If your over say 20 miles away from the transmitter with a trunked system, you may have issues acquiring, or even decoding the CC.
If your just trying to find NEW TG's... scan in OPEN mode..
If you already know the TG's you want,... scan in CLOSED mode...
