pro 2067 Trunking
krw
Scarborough, Ontario
Hi all,
I have a new to me pro2067 scanner. I have programmed analog trunking frequencies and id's in it with Win92. I also have a couple conventional frequencies as well.
The problem is: it will not stop on trunked frequencies or id groups. It will stop on the conventional frequencies though.
If I put it in manual mode, I can then pick up trunking.
Squelch is set to a bare minimum
I am not new, but this has confounded me to the point where I ask for help.
Cheers,
krw
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
It would be most helpful to know what system you're trying to trunk...folks can help you after that....Mike
spooney
Indiana
If the trunk systems are EDACS or LTR do not put the first LCN frequency in the 0 channel position. Always leave 0 blank and start with channel number 1.
spooney
Indiana
Oops, sorry. The systems are Motorola II. An example would be TIR in Nova Scotia.
Your problem could be a re-banding issue. The 2067 will not track a re-banded system. If you haven't done so already try putting in all the freq's for the system and maybe it will start tracking.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Rebanding has no effect on Canadian systems...here are all the trunk systems in NS we have in our database...
Nova Scotia Trunking Systems
Note that the very last one - the one marked as Project 25 - can't be trunked with the old 2067. The others are possibilities, assuming you are in range of these systems.
We do have a wiki on programming the 92/2067 manually and this might give you some hints as to what might be wrong...
Programming Shortcut Pro-2067 - The RadioReference Wiki
and it kinda shocks me, but there's even an Easier to Read guide for the radio...
Easier to Read Pro-92/A/B/2067 Scanner Manual
Now, which one is it? Mike
krw
Re:
Thanks everybody for your replies.
I think this is an issue with the scanner and not necessarily the way I'm programming it,
What is driving me crazy though is that I can manually go through the scanner and pick up the
trunked frequencies and id's and follow the conversations. As soon as I hit scan, it skips right pass
the trunked frequencies. It will however stop on conventional frequencies.
Again, thanks for all your help.
