PRO 2096 After ARC96 upload, won't scan.
The PRO 2096 was working ok and scanning the limited number of freqs I had manually loaded.
I purchased ARC96 and retrieved several banks of freqs from RadioRef.
After uploading that data to my scanner, the scanner will no longer scan.
I can open the squelch all the way and there's no static noise (volume all the way up.)
I programmed banks 0 through 5 and 0 blinks but doesn't move on, even though the screen says, "Scan up . . . "
I'm new to programming the scanner other than manually, but trying to learn.
If I press PROG, I can step through the channels and they are loaded with the freqs I selected in ARC96.
Not sure where to go from here.
Any help appreciated.
John
John
