what the heck does that mean and how do I fix it?
Already tried reset and initialize. No change.
Any help please?
Sarge
Any help please?
Sarge
That is why they are all locked out! By default, empty channels are locked out as they cannot be scanned.I have win96. There is nothing loaded in the scanner right now.
What programming cable are you using?ok tell me this. obviously I'm doing something wrong. using win96 and radio reference. Do I need to set the scanner some way before it will take the upload?
That all sounds like it should.yep using the adapter and clone mode comes up
It sounds like you are doing something wrong in Win96.ok how do I do that? I switched from the PC to the laptop. I have win96 set to read back and it seems to upload without a problem. Then I unplug the cable and hit trunk or scan and still get all channels locked out.
That is great! Gommert writes some good stuff and I often use both his as well as Don's.bought ARC96 and finally there is joy in Muddville !
I know that you got your scanner running, but, when you say adapter...........Did you use the extra piece that came with the USB cable? If you did, it won't read from the scanner, or send to the scanner. Just use the cable without the extra adapter. Used to have a 96 and never had a problem with either the RS232 or USB cable.yep using the adapter and clone mode comes up
Are you sure that is not reversed? I've always needed the extra adapter for the Pro 93,95 and 96. On those three models, mine only needed the tip and sleeve and not the ring. On the newer GRE based digital models then I cannot use the adapter as they require the tip,ring and sleeve.I know that you got your scanner running, but, when you say adapter...........Did you use the extra piece that came with the USB cable? If you did, it won't read from the scanner, or send to the scanner. Just use the cable without the extra adapter. Used to have a 96 and never had a problem with either the RS232 or USB cable.
Larry
Really?! Yes, I did use the extra piece. Maybe I'll try it without that to do the next bank. I just ASSUMED I needed it since it was there.I know that you got your scanner running, but, when you say adapter...........Did you use the extra piece that came with the USB cable? If you did, it won't read from the scanner, or send to the scanner. Just use the cable without the extra adapter. Used to have a 96 and never had a problem with either the RS232 or USB cable.
Larry
Check out this article from the Wiki; Connecting scanners via USB - The RadioReference Wiki thisAre you sure that is not reversed? I've always needed the extra adapter for the Pro 93,95 and 96.
