Pro-2096 and Pro-96 Reception Issues on Colorado DTRS
markstanwood
Fountain, Colorado
Hey everyone,
I'm reaching out because I'm having some frustrating issues with my Radio Shack Pro-2096 and recently acquired Pro-96 scanners. I use these to monitor the Colorado DTRS, specifically for El Paso County Fire, El Paso County Law, and Colorado Springs Fire Department (CSFD).
Here’s what’s happening: sometimes the scanners work great, picking up signals as clear as day. Other times, it’s like the main county law enforcement channel is right next to me, but I’ll struggle to receive other channels consistently. For example, I might only get the county fire command channel or just the CSFD dispatch, but not their command channels.
I’ve tried everything I can think of—different programming, settings tweaks, you name it. Some days it works well, and other days it’s hit-or-miss. Could this be a programming error on my part, or is it possible my equipment has issues? Any advice or suggestions would be greatly appreciated!
Thanks in advance for the help, and I hope you’re all having a great day!
wtp
Port Charlotte FL
are you listening to the simulcast tower ?
4 (4)011 (B)Fountain ValleyEl Paso, CO852.1125854.7125855.0875856.0125856.7625856.9875c857.9875c
858.9875c859.9875c
4 (4)014 (E)CalhanEl Paso, CO851.125851.2875851.700c852.2125c853.125c853.825c854.2125
857.9125
4 (4)018 (12)Mount PittsburgEl Paso, CO851.2875852.050852.550852.6375853.1875853.6625853.7375c
854.0375854.2125855.2375856.2375856.4625857.2375858.2375c
4 (4)019 (13)TrucktonEl Paso, CO853.800854.3875855.7125857.4875c858.4875c859.4875c859.7375
4 (4)028 (1C)Colorado Springs SimulcastEl Paso, CO851.875851.900852.075852.3375852.400852.6125852.7625
852.800853.3625853.3875853.6375853.7125c853.7625c853.8875c
854.1125857.0125858.6125859.0125c
6 (6)039 (27)Quail LoopEl Paso, CO856.3875856.8375857.3875857.8375858.3875c858.8375c859.3875c
859.8375c
6 (6)048 (30)Cheyenne MountainEl Paso, CO851.050851.200851.3875c851.725c851.9625852.7875c853.050c
853.475854.3625854.6625856.0625856.6625858.0875
tvengr
Well Known Member
Baltimore County, MD
Are you programming each site in a separate system in different banks? The PRO-96 and PRO-2096 allow only a single site per system. If the Colorado Springs site is the only one giving problems, it is probably due to simulcast distortion. The PRO-96 and PRO-2096 are very old scanners. They are known to have the frequency drift on 800 MHz frequencies. Frequency accuracy is critical for decoding P25 systems. If the problem occurs on all sites, adjusting VR4 in the PRO-96 and VR3 in the PRO-2096 may help. If you are using ARC96 software, please attach your programming file so I can take a look at it. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file.
Ronaldski
MI DB Admin
Bay City MI
Colorado Springs does have a simulcast site, State of Colorado DTRS Trunking System, Statewide, Multi-State
Also I do see encryption in use, MODE column with DE, then D is in the clear. So dont program in the DE's.
I see your a premium subscriber and may have downloaded with software to program.
Just a few items, be sure the tower frequencies are set to MOT.
Just program in the control red color frequencies, you'll find the scanner will be more responsive.
Be sure to have set the system itself to Trunked.
Always can attach your programming file on here so we can check it out.
If I recall right, when no one is talking press MAN on the digital system tower nearest to you ideally and should hear some digital noise coming from one of the control channel frequencies. Signal % will show up, ideally should be ~90% or better or if that jumps around to very low and even 0% likely is an indication that the vr3, 4 drifted.
I suppose both could have the vr4, vr3 drift. I have fixed ~a dozen of them with that, not scientific with a small screwdriver, usually about 5% turn counterclockwise tends to work.
Spitfire8520
Might be slightly less clueless! =)
Colorado
El Paso County and Colorado Springs are site specific and require careful programming to be able to receive what you want consistently. I think the issue you are most likely running into is that the vast majority of communications in the county will be on Colorado Springs Simulcast, especially for Colorado Springs, which means you will have to deal with simulcast distortion. Simulcast distortion is an issue with most scanner hardware struggling with receiving simulcast sites, which is a site that has multiple towers broadcasting the same signal. You can see the locations of the individual towers by visiting the linked site.
Scanners often fail to decode the signal depending on local conditions and will try to listen to other sites that you have programmed. The problem is that the other sites carry less variety of traffic as they are intended for more rural coverage. You will probably consistently hear county on it, but you are less likely to hear Colorado Springs on it due to a trunking concept called affiliation. The system administrators also deny Colorado Springs talkgroups from affiliating on some of the rural sites because they are meant to be used by the county agencies. The linked wiki article on simulcast distortion has a list of suggestions you can try to reduce the effects of simulcast distortion, but they are not guaranteed to work. I think of all the suggestions, a Yagi antenna isolating a single tower is probably the most consistent, but it may not work depending on your location in relation to the towers.
The only real solution in a scanner form factor is getting a Uniden SDS100 or SDS200.
The other issue you could be running into is that El Paso County is largely restricted to Zone/RFSS 4 sites only. Some specific talkgroups might be allowed on the other zones, but trying to listen to a site in a different zone will lead to a significantly reduced coverage of agencies in El Paso County. This means that Cheyenne Mountain is a bad choice unless you specifically want to listen to everything else that is not an El Paso County agency. I suggest treating El Paso County/Colorado Springs as a separate system from the rest of DTRS when it comes to programming your scanner.
