I would also check the NOAA first. Last year I had a situation with a customers scanner (Pro106) that sounds similar. After digging out my notes on it I found the solution in V Scanner Memory. It was my solution, maybe not yours. He brought in a Pro106 for programming, I use Win500 and W96 to program scanners. (not a clone scanner to scanner). After failed attempts, I found I could program the file to a V folder, call it up on the scanner and it worked. I do not know why the main memory did not work but the V folder did. You mentioned you were using Win96, when you click on the scanner tab, choose virtual scanner instead of download to scanner. Follow the flow in the program, choose the file you want in the scanner. If you have access to the owners manual, take a peek at the V Scanner Memory section. Hope this may help or lead you to an answer.
