My Pro-2096, which probably has less than 10 hours of use, seems to have broken on me tonight. I was using the scanner, scanning though a custom V-Folder, and all was well. I turned the scanner off for a couple of hours, and when I returned, I turned it on, and now the scanner will not receive ANYTHING.
I had banks 1-5 & 9 enabled, but the scanning "cursor" would not leave bank one. So I do the ol' standby scanner test, and hit the WX button to hear the harmony of the electronic weatherman, but it will not RX the WX either! Each time I hit the WX button, it will simply go to the next WX freq, but will still not pick up anything.
After fooling around with that for some time, I went to the stock VA-MD-DC V-folder, and this folder does the same thing to me. It will not do anything but sit there with the cursor flashing in Bank 1.
I have used both the included telescoping antenna, and my Diamond D-130J discone, with no change. I also did a full reset on the scanner using the reset button, and I still get the same results: the scanner acts like there isn't an antenna attached.
I am at wit's end with this. Does anyone have any other suggestions, or will my 2096 be making a trip to Fort Worth for repair?
TIA for any help!
TIA for any help!
