Pro-2096 on Hamilton County, Ohio TRS?
wolverine
Cincinnati, Ohio
Has anyone placed an order yet for the Pro-2096 to monitor the Hamilton County, Ohio system and if so, can you post how well it does over the Pro-96? Does it receive any better on the system then the Pro-96?. Thanks.
FPO703
Planet Earth
The PRO-96 & PRO-2096 are the same radio. One is handheld, the other base/mobile. There's no difference other than cosmetics.
scannerfreak
Well Known Member
Indiana
The problem with HAMCO is in the system itself and has nothing to do with the scanners ability to monitor it.
wolverine
Cincinnati, Ohio
I wonder why the XTS5000 on the system have no problem at all receiving transmission on the system and the scanners are.
royalzapper
Hamilton County [Ohio]
scanner_freak
I do not think the problem is the system I think it is the scanners.
Put the INPUT frequencies in your scanner and when you are close
to a unit you can hear them.
The best test will be with the Oxford, OH system!!
royalzapper
scannerfreak
Well Known Member
Indiana
royalzapper said:
scanner_freak
royalzapper
Then why is it it works fine on other C-QPSK systems?
PS- And yes even the radios have their issues as well. Granted not as bad as the scaners, but you would expect that.
radioscan
Radio Sensei
Southern Ohio
I really don't believe it is the radio. I think it has to do with not getting all
the sites in the system in sync. Maybe that will happen once the Cincinnati system is fully online.
