PRO 2096 Question
Griggs
Hamilton NJ
Is the PRO 2096 capable of receiving trunked frequencies on a 500MHZ Moto type II system? I was told the 2055 I currently have are not capable of this. Any input is appreciated.
LEH
Yorktown, Virginia
I have not tried a 500 MHz system, but the 2096 does track my 400 MHz DOD system.
Now you may have to set the table(s) up to receive the system. The base, offset and step. If the system has more than one table, then the only way to get it to work properly is to use software to program the scanner. The scanner cannot do more than one table manually.
Where is the system located. It should have the table info in the DB for your settings.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Yes, the 2096 will do the Ocean Co 500 system and so should the 2055 for analog transmissions.
Set the tables using:
PGM>TRUNK>FUNC + 2 Then FUNC + 3 to Table.
Griggs
Hamilton NJ
I am looking to listen to Burlington Cnty's 500 trunked. How do I go about chagning the table in Win97 for the 2055??
fmon
Eclipse, Virginia
Right upper side of selected Channel tab set the tables for Base, Offset and Step
Don't program any talkgroups with a D (digital voice) under Mode. It appears all of the police are digital.
fmon
Eclipse, Virginia
To program this system in the 2096 with Win96 select Multi table under MOT 3600 CC and set the first three tables as in this illustration.
torontokris
Toronto Canada
As fmon pointed out you may need the WIN96 in order to program those tables (is the system needs them)
torontokris
Toronto Canada
Because its original frequency coverage does not include any 700, so no possibility of monitoring it (even with extended freqs & Custom tables)
Maybe the maker of Win 96 can comment on why that is
25-54 5 kHz
108-136.9875 12.5 kHz
137-174 5, 6.25, or 7.5 kHz
216.0025-221.9975 5 kHz
222.000-225.000 5 kHz
406-512 6.25 kHz
806-823.9875 6.25 kHz
849-868.9875 6.25 kHz
894-960 6.25 kHz
1240-1300 6.25 kHz
I'm curious now -
If the 2096 will track these frequencies - why won't it track the 700MHz frequencies used by ASU out here?
See this thread: http://www.radioreference.com/forums/showthread.php?t=117984
