What is the command to switch back to working memory from V Scan folder? I can't seem to find a reference to it..........Do the memory in the working memory bank get deleted after loading a V Scan folder into it????
Below are tutorials on how to load/save data with V-Scanner memory. The illustrations are for a PRO-96, but the instructions, and buttons are the same for your PRO-2096.
This doesnt answer my question. I know how to load the VScan folder to working memory. My question is how do you get out of the V Scan folder in working memory and restore the memories that were there before loading??
If you read what I sent you it does answer your question. Take another look at the second link. Apparently it just doesn't tell you what you want to hear.
You don't scan from a V-Scanner folder, you scan from the scanners working memory. When you program your scanner, you are programming the working memory. If you load a V-Scanner, you overwrite your working memory with the contents of the V-Scanner folder. If you didn't previous save your scanner's working memory into a V-Scanner folder, then it is gone.
There are nine V-Scanner folder, that you can save, and load. There is an additional scratch V-Scanner folder that you can use as a temporary storage folder while manipulating V-Scanner data. It's all covered in the information at the links I sent you.
You need to press Pgm-Func-Pgm, then "Save" your "Work Pad" to "." (decimal point) enter, the scanner will then save your original Workpad to the "scratch pad folder", you then press "load", it asks what VFolder you want to load....After you load say VFolder 8 and you want to reverse the situation you go in reverse and "Save" VFolder8 back and "LOAD" "." back to your "Workpad"...your original work is back....
