pro-2096 ?
cmjonesinc
If ravenkeeper doesn't have a bracket this one should work.
A 2096 should be the same as a pro 197 so it should fit.
Ravenkeeper
Antelope Valley, CA
How much would you charge and would you happen to have the mounting bracket.
Thank you in advance.
I know I have the screws for mount it, I'll have to do some serious digging in my garage IF I have the bracket. If I have the bracket, I know which one of five bins it could be in.
My radios are currently on a 9" bracket. The attached picture is from when they were in my 2015 Silverado. I'm still working on getting them set up in my 2018 Silverado. The "top of the bracket" is sitting in the bottom of the center console and supporting the radios up near the top of the opening. ( \*/ basically. )
cmjonesinc
Where did you get that bracket? I definitely could have used one of those a while back but had to make one.
Ravenkeeper
Antelope Valley, CA
