PRO 25 change priority channel
noseynody
Eastern Ontario
Hi
Can someone tell me how to change the priority channel on a Realistic PRO 25?
I am trying to change the priority channel from 70 to 16. When I try as it says in the manual, program, channel number, priority, it takes me from channel 16 to the existing priority channel 70.
Somehow I changed it from factory setting of channel 1, but that was 30 years ago :)
pro92b
Mutated Member
PRO-25 100-Channel Programmable Scanner (200-0505) made by Uniden sold from 1995 to 1997.
Quoting exactly from the manual:
To program a channel as the priority channel, press PROGRAM, the desired
channel number, then PRIORITY. P appears beside the channel number.
I don't own a PRO-25 but if the procedure in the manual just doesn't work, try the steps below to change the priority channel from channel 70 to channel 16.
Press MANUAL
Enter 16 then press MANUAL
Press PROGRAM
Press PRIORITY
