PRO-26 replacement speaker
Mork
Connecticut
Hi all:
I have a nice PRO-26 handheld that has a blown speaker. Can anyone advise where I can get an exact replacement. This one is very thin and I haven't been able to scavenge from my parts bin.
doc
Mork
Connecticut
Thanks Doug.
I'm hoping to find a source for an exact replacement rather than having to rely on my (lack of) sight to measure all the specs and order from suppliers. Like someone who might have a parts unit with a good speaker from whom I could purchase a replacement.
doc
pro92b
Mutated Member
RadioShack.com
The link above contains parts lists for many Radio Shack scanners. It shows the PRO-26 speaker as CAT NO. 11085388 SPEAKER, SP326 8 OHM 1W NP PART # SP0464. The same speaker is used in the PRO-29, PRO-51, PRO-67, PRO-71, and PRO-90. Maybe you can order the speaker from Radio Shack although all these scanners are quite old.
Another option is G&G Communications. They list a Uniden speaker that I believe is the one in the PRO-26.
BSPY0326001 UNIDEN BC220XLT REPLACEMENT SPEAKER 1.5 Inch Low Profile Models BC120xlt-220xlt-235xlt-245xlt-Sportcat150 NEW $13.50
KC5EIB
Flower Mound, TX
I will be back in the store on Wed and check the other scanners for availability of speaker replacements.
pro92b
Mutated Member
Later production of the PRO-71 and PRO-90 (the 'A' versions) used a replacement part number that should be physically compatible.
12128864 SPEAKER SP-396 36P-08W SP90185
KC5EIB
Flower Mound, TX
I had also looked at the PRO-29, PRO-51, PRO-67, PRO-71, and PRO-90 and replacement speaker is not available for those radios either
