Pro-39 Some Keys Don't Work
ronmicha
memphis, tn
I've got an old Radio Shack Pro-39 handheld and suddenly the "3" and "6" key will not operate. Has this ever happened to any of you? I opened it up and hit it with some compressed air with no results. Don't have any contact cleaner but could get some. Any of you have any helpful hints? I don't use it a lot but obviously I need those keys to work.
Thanks.
Ron in Memphis
KE5BCP
Analog Man
Lewisville, Texas
Thanks.
Ron in Memphis
I had this happen with my first scanner (Pro 50) a few years back. I used contact cleaner, as well as replacing the keypad itself. Good luck!
Colin9690
County 21
APE282018
Yeah, replace that keypad. The old Realistic (RS) scanners' keypads tend to wear down when they are that old.
Good Luck! :)
LarrySC
Greenville, SC
Replacement keypads havent been is stock for 7 years. Carefully remove keypad. Clean circuit board with pencil eraser. Clean keypad with cleaner and cross your fingers.
Al42
Long Island, NY, USA
VERY carefully and VERY lightly. You just want to take off the surface film of dirt, not the contact itself, which is only a couple of thousandths of an inch thick. Pink Pearl erasers are less abrasive than the ones on the ends of most pencils.
