zonian149
I have a pro-43 that I bought off ebay. It has been working great using batteries, so today I decided to play with the charger that came with it radio shack No. 20-188 9v dc 300mA. The scanner worked fine with the charger plugged into the power port on the scanner. I had the charger unplugged and plugged it into the charge port on the scanner and then plugged it into the wall outlet. When I unplugged it from the scanner the scanner does not work just on batteries, I have to plugged the charger into the scanner power port for it to work. Any ideas as to what happened or what I can do to make it work again on batteries. If I haven't got you confused.--Gary
