im looking for wall wart sizes for these two scanners
and which tip sizes i need for them
thank you all
im looking for pro 51 radio shack type now/as of june 17th
also-780xlt wanting to buy
Get the program PDW v1.1 and a scanner with a discriminator tap and it will decode pagers for you. If someone uses IPN in your area you will see it on your comp.
thank you all
The Pro 51 uses the H (273-2711) adaptaplug and the 93 uses the B (273-1705). Any 9-Volt with at least 300mA wall wart with the correct fitting for the above adaptaplugs will work.
273-1767 or equivalent is a 9v 300mA adapter with a fitting to accept either adaptaplug above. Or if RS still has it, 273-1665 is 9V 300mA with a fixed H fitting which will work for the Pro-51 or 92.
