PRO-51
N1KWW
There are two power options, one disconnects battery power other powers scanner and recharges internal capacitor for memory. The two locations are on the left side, can someone tell me which is which. Want to operate scanner and recharge capacitor.
Thanks in advance,
Fred, N1KWW
N1KWW
Apologize!
The power connections are posted on the back indicating which is which.
Blaming it on "senioritis!" or a brain fart!
slicerwizard
Toronto, Ontario
There are two power options, one disconnects battery power other powers scanner and recharges internal capacitor for memory. Want to operate scanner and recharge capacitor.
Scanners from that era don't use volatile memory, so there is no capacitor to recharge. The charging jack is for recharging NiCad batteries only. If you're using alkaline cells, you'll ruin them as well as the radio.
pro92b
Mutated Member
The charging jack works as Slicerwizard said. However the PRO-51 is one of the last radios to use a capacitor for memory back-up. The manual says it will hold memory for up to 3 days during power loss. The capacitor is: C203 10555225 CAP .047F +80-20% 5.5V DOUBLE LAYER For more info see RadioShack.com
slicerwizard
Toronto, Ontario
Oh well, I tried, but the RS support site was light on details and I couldn't find any references to volatile memory or backup caps. I guess it's safe to say that power applied to either jack will keep the cap topped up, so just use the power jack (probably the upper jack) unless you're recharging NiCad or NiMH cells.
