PRO-528 Charing Problem
E-542
Lancaster, PA
Whenever I plug my 528 in to charge, it won't charge at all and the display reads 'ERR CHAr9' What's goin on? Thanks.
Bucko
Marietta, Ohio
Have you checked the output of the charger adapter to make sure it has the correct voltage output? That would be my first suspect before the scanner itself (jack, batteries etc.).
E-542
Lancaster, PA
No it's correct, went to Radioshack itself for it. It's worked before, but now..
kramdeer
Kansas
ever figure it out
hey did you ever get this figured out? mine is doing it as well it was just fine but I haven't had it plugged in for about a month and I plugged it in to charge it and that came up. I've had the batteries for almost 3 years could they be bad, and be causing this?
E-542
Lancaster, PA
No, still havin the problem with it. It's not the batteries, cause, if I take the batteries out, and run it off of the charger only, it still won't work.
