robo21
I recently purchased a nice soft leather case for my new Pro-651 at Scanner Master and they followed up with an email advertising a W-801 antenna which they claim "is a big improvement over the standard flexible whip normally provided with handhelds."
In my follow up surfing around the Web I have seen more advertising that claims that this antenna offers anywhere from 2 to 6 times the signal grabbing capability of the stock rubber duck antenna that came with my scanner. Some more outlandish ads talk about "100's of times better" reception. Sounds like hogwash to me.
All of these replacement antennas, just like the stock antenna, are compromises in their ability to grab the wide range of signals these scanners were designed to receive. I don't know if someone else's compromise is going to be any better than the stock compromise antenna. So I am calling on the community's experience here.
First, my listening ranges from the CHP down at 43-45mhz occasionally, to city services ranging from 150-166mhz, 450-460mhz, 480-485mhz, 500-510mhz and sometimes 800-830mhz range. Most of my listening (85%) would be in the 480-510 range. I frequently hear broken transmissions in this range so it could be that I need a better antenna.
I am interested in improving my reception but truthfully, I am skeptical that these aftermarket antennas are any better than stock. It makes some intuitive since that a telescoping antenna might help as the wavelength could be adjustable by stretching out or shortening the antenna depending on the target frequencies. However, I don't like the look of this type of antenna so unless it is going to be noticeably better I'd just as soon stick with the stock antenna. The telescoping antenna does have a price advantage but that doesn't matter if it doesn't improve the reception.
Furthermore, I do realize that for the best reception I need a rooftop/outdoor antenna but that would require more time and energy than I can commit at the moment.
So, fellow scanner hobbyists, what are your thoughts? And has anyone tried the W-801 from Scanner Master specifically? a
