Pro-668 Battery / Power Icon Behavior
garysauctions
So tonight I noticed an odd behavior when connected to an external power source via USB.
I have nimh rechargeable batteries installed.
Internal switch is in correct position.
Now the battery icon looks norman,you can see it indicating it is charging until ......
A signal is received.
As soon as audio begins the battery icon shows the PLUG icon as if on external power when no batteries are installed or alkaline are installed.
Is there a setting in a menu for this that I may have set inadvertently?
ALSO - what is the proper method for doing a complete reset back to the condition it was in when removed from the box?
THANKS
buddrousa
My guess is that the scanner draws more during receive than the charger put out. If I leave the scanner on with fully charged batteries over night recording even with the volume turned all the way down the next morning the scanner is only 3/4 charged this is with new fully charged batteries charged on an external charger.
AtlasFBG2
Fremont,Ohio
That is the way it is supposed to work. When the audio is unmuted it stops charging.
Version 2.3 - August 20, 2014
Charge while powered on. Charger disabled while audio unmuted.
Increase frequency of battery level updates.
Only show minimum battery level, instead of averaged.
Changes to "Charge Time" affect charger in real time.
If you want to reset it back to out of the box condition. Go to the pro-668 software on your computer click file then new configuration. Then click scanner/sd card. Then prepare sd card for use. Check the two boxes in the after format option seting. Then format.
buddrousa
What does resetting the scanner have to do with the charging circuit NOTHING you can only set the warning voltage for the low battery warning. That is not the way it should work I hope that would be something a firmware adjustment would fix. But defaulting the scanner will have no bearing on this charging problem.
AtlasFBG2
Fremont,Ohio
That is a copy and paste from the 2.3 firmware release notes. It disables the charger when there is audio. That is what the firmware says it is suppose to do.
He also asked how to reset the scanner. Which reformatting the sd card will put it back to out of the box condition.
buddrousa
That is funny The release date for the PRO-668 was 1st week of Jan 2015 YOU ARE POSTING WS-1080 or PSR-800 the firmware is different for the RadioShack PRO-668. Could you please point to the RadioShack FIRMWARE posting. Also the FCC report date was was Sept 1 2014 you can not have updates for a product that is not approved for sale
AtlasFBG2
Fremont,Ohio
Whats funny?
RadioShack PRO-668 Digital
Handheld Trunking Scanner
CPU Firmware
Release Notes
Version 2.2 - July 29, 2014
Initial RadioShack Release
http://scanner-update.com/pro668/public/cpureleasenotes.html
Whistler EZ SCAN Digital
CPU Firmware
Release Notes
Version 2.7 - April 16, 2015
Fixed Audio Boost handling for analog frequencies.
Version 2.6 - March 3, 2015
Changed algorithm used for battery level icon.
New default voltages for NiMH icon thresholds.
Version 2.5 - December 9, 2014
Fixed EDACS patching bug.
Add delay in USB startup required by some USB host hardware.
Version 2.4 - August 20, 2014
Version 2.3 - July 29, 2014
Initial Whistler Release
http://scanner-update.com/ws1080/public/cpureleasenotes.html
GRECOM PSR-800 EZ Scan Digital
CPU Firmware Update Release Notes
Version U1.9 - December 9, 2014
Version U1.8 - January 15, 2013
Added ability to decode APCO Project 25 Phase 2 TDMA voice channels. This version must only be used in conjunction with DSP firmware version U1.3 or later.
When this version is installed, the uP Appl Ver line on the version screen (accessed by pressing the MENU when the welcome message is displayed after a power up) will show as version 1.8.
When a Phase 2 talkgroup is active, the scanner will display "D2" instead of "DG".
We recommend ensuring the sites on a P25 Phase 2 system be set to Auto-Fill mode. This will allow the scanner to automatically set the information needed to track the system from the control channel data stream. Don't use "custom tables" for Phase 2 systems unless you really know what you're doing.
Added support for decoding of radio ID and priority channel detection since the release of Beta 2.
Fixed issue in the Beta 2 versions with the scanner not returning to the control channel when a Phase 2 transmission ends when the other time slot is in use on the same frequency.
Version U1.6 - July 25, 2012
Fixed private call wildcard bug on Motorola and EDACS systems.
Added "ScanSets Opt" setting. If enabled (checked), Scan Sets alone govern whether a scan list is scanned; the master Scan List enable array is ignored.
Add option to tune to encrypted voice calls on Motorola systems. While the scanner will tune to those talkgroups, the scanner cannot decrypt the voice data being received.
Add option to tune to digital and/or encrypted voice calls on EDACS systems. While the scanner will tune to those talkgroups, the scanner cannot decode the ProVoice data or decrypt an encrypted voice channel.
Fixed 5th line not being cleared in "simple displays" mode, when going from a TGRP to a CONV object.
Fixed apparent "stuck" alternating displays when the display is updated frequently.
Fixed CCDump-to-file when loading a new V-Scanner folder.
The CCDump log count is now configurable. Available choices are 100, 200, 500 or 1000. This change also required the file name change to DUMP_nnn.LOG.
Note: Using a setting of 1000 can overwhelm a 2GB Micro SD card pretty quickly if most of your scanning is done on trunked systems.
Version U1.5 - January 9, 2012
Verson U1.5 adds a new import option to the PSR-800 scanner.
When enabled the scanner can import all frequencies systems based on a combination of County, City, or Zip Code and the usage tag (i.e. "Multi-Dispatch", "Law-Dispatch", "Fire-Dispatch") seen on the RadioReference.com web site.
When the Location Select option is enabled, scan lists 151 through 200 are renamed to match the usage tags present in the library database. Items imported via the Set Location menu will be placed in these scan lists. If custom alpha tags for these scan lists exist, those names will be preserved should the location select option be later turned off.
This new option is accessed via the Set Location menu option provided the following conditions are met:
Location Database files must be installed on the scanner's Micro SD card. These files are available and updated via the PC Application and may be installed using the "Check for Library Updates" function or the "Copy Library to Scanner/SD Card" option.
The Frequency Library Database must be at version 84 or later. These files may also be updated using the PC Application.
The "LocationSelect" option in the scanner's Settings menu must be checked.
Beware: Using the "Clear Channels" option in the Set Location menu will erase ALL conventional and trunked data in the currently selected V-Scanner folder.
Updated the battery icon process voltage levels to more accurately show the current state of the batteries.
Minor changes to the low battery shutdown order to minimize the slight chance of SD Card corruption due to uncontrolled shutdown.
Public Safety search and sweeper ranges have been changed to correctly reflect current band usage.
In object browser, added audible indication to up/down keys that you've passed the top/bottom of the scan list's contents
In CCDump, added EDN vs. EDW indicator based on current site
Disable all location-setting items if the Bandplan is set to Canada in the main Settings menu.
Fixed blank "site" tag in playback (when no site tag stored, was alternating TSYS tag with a blank line)
Fixed handling of SKIP key in V-Scanner delete confirmation
Optimizations to library browse/select code
Changed 154-156MHz range to accommodate Marine channels while also preserving pre-1.2 frequencies
Re-arranged main menu items per suggestions
changed default 'on battery' light mode to KEY (though the power key would always do the same thing) per suggestions
changed default backlight brightness level to 4
Added 'delete' function (via SKIP key) to V-Scanner browser
Fixed bug in loading V-Scanner folders (wasn't properly closing CONV and TSYS files that might be open, resulting in 'object read errors')
In the Set Location menu, there is a "Backup Data" option. It will copy the current configuration to the first (lowest-numbered) available V-Scanner folder, indicating that number to the user when the copy is complete. The "description" text for the folder will be:
Backup from Set
Location menu:
Date: yyyy-mm-dd
Time: hh:mm:ss
In the V-Scanner function, pressing SKIP will now delete the displayed V-Scanner folder. The user is prompted to confirm that he really wants to delete the entire folder. The user cannot delete the "default" folder or the currently-loaded V-Scanner folder. If he attempts to do that, he’ll get one of these messages:
Can't delete
default folder.
Press SEL
- or - Can't delete
current folder.
Press SEL
Version 1.4
Not publicly released.
Version 1.3 - July 25, 2011
Corrected USA band plan to accommodate marine channels 1 and 5 while preserving the frequencies available in CPU firmware prior to version 1.2.
Version 1.2 - May 24, 2011
The USA bandplan has been adjusted as follows:
Previous Band Plan:
154.650000 – 156.255000 MHz, 7.500 kHz steps
156.275000 – 157.450000 MHz, 25.000 kHz steps
New Band Plan:
154.650000 – 156.045000 MHz, 7.500 kHz steps
156.050000 – 157.450000 MHz, 25.000 kHz steps
This change resolves an issue with marine band channel 1 (156.050000) and 5 (156.250000) not falling into the scanner's bandplan.
Pressing left arrow key in SCAN mode now goes directly to Browse Objects mode, on the last object monitored.
Added option to show ONLY the RadioID's alpha tag for group calls. If this option set, you get just the tag (if one is available); otherwise, you get alternating tag / numeric ID.
"Show Radio ID" "tag only" Result
N - No Radio ID info shown
Y N ID alternating with found tag (if any)
Y Y Just the found tag, if any. If no found tag, just the ID
Fixed bug in search mode which was causing a crash if you pressed SKIP in Railroad mode.
Added "FlexStep" control to main Settings menu
Changed initialization code to address "freeze at startup" problem
Fixed backlight not turning off in KEY, IGNORE, and NORMAL modes when object alert is turned off (was staying on if the backlight was already on when the object alert went active)
Added TSYS index (i.e. "file number") to recording header
Fixed bug in priority talkgroup handling that would cause scanner to "lose" the current talkgroup in the Browse Objects, Play mode
Version 1.1 - March 4, 2011
NOTE:
Due to enhancements made in the firmware's use of the microSD card, it may be necessary or desirable to re-format the card using the PC software after installing firmware version 1.1:
Using the included USB cable, attach the scanner to a USB port on your computer. Leave the scanner "turned off" (it should be showing its clock display).
For better speed while reloading the microSD card with your data, you may remove the microSD card from the scanner, and insert it in a card reader on your computer.
Launch the EZ Scan Digital PC software
From the software's "Scanner/SD Card" menu, select "Prepare Scanner Memory/SD Card for use"
In the dialog box that appears, check the three checkboxes and select the drive letter that corresponds to the scanner microSD Card - this is likely indicated with a volume name of "EZSCANDG".
Click the "Format" button and follow the prompts
Close the EZ Scan Digital PC software
If you removed the microSD card from the scanner and used a card reader attached to your computer, remove the microSD card from your computer and insert it back into your scanner.
Changes since version 1.0:
Enhanced the speed and reliability of writing data to the Micro SD Card.
Speed up adding new conventional channels from library
Fixed issue with P25 encryption mute not always activating when it should be.
Fixed priority talkgroup function while monitoring another talkgroup.
Optimizations to "delete" functions in playback menu.
In playback display, allow for more than 99999 recordings
Allow decimal display of P25 private call IDs (aaa -> bbb), if the ID values "fit" in the 16-character display.
Changed default "CountryBandplan" to an invalid value so that startup code will prompt the user. Tuning code will interpret the invalid value as "USA".
Added "Set Bandplan" function, called at startup (before clock set) if the GLOB setting isn't valid (e.g. it's the default)
Small optimization to CCDump->file writing.
NOTE: The "PC/IF CCDump to file" option is incompatible with any USB serial operations.
Version 1.0
Initial Public Release
http://scanner-update.com/0602902/public/cpureleasenotes.html
Blackswan73
Central Indiana
The firmware was written before the scanners were released. Whistle shack posted links to firmware archives and release notes for both the 668 and 1080. You do not need to use computer to reset. Just press menu, scroll down to "settings" and select. Then select "default values" Resets to default as out of the box
AtlasFBG2
Fremont,Ohio
AtlasFBG2
Fremont,Ohio
Ok buddrousa try this.
Open the pro-668 software on your computer. Connect you scanner with it powered on. Click on updates. Click on check for cpu firmware updates. Click check for updates. Then click view release notes.
Since it is coming directly from the Radio shack iscan software maybe that will be official enough for you.
buddrousa
Atlas sorry I just did not understand why there was a firmware update before the scanner was ever built or approved forsale by the fcc. Anyway makes no sense to stop the charging circuit when audio is unmuted. What does not make any sense either is why you built the scanner and not use updated firmware at the factory.
garysauctions
Because the units were manufactured and shipped to warehouses while awaiting FCC acceptance.
FCC acceptance in most cases is just a formality, especially in the case of RECEIVERS.
Units roll on down the assembly line while programmers are working on updates.
buddrousa
The PRO-668 did not clear customs until the last week of Dec 2014 or the first week of Jan 2015. Well the good side of the x36's 668's 1080's 1095's is that most all the functions are just software changes as compared to the older 197's 106's 500's 600's which would have had hardware changes if not approved. The build date for mine runs real close to the FCC approval date that is all I was going on. I remember reading the x36's did not leave the factory for the warehouses until after the FCC approval date. Sorry to get off topic.
garysauctions
This does not mean the units were not sitting in warehouses on US soil.
Lots of merchandise enters the United States on a daily bases and is held in secured warehouse awaiting clearance by US Customs.
DonS
Franktown, CO
It makes sense when having both active (charging and audio output) can cause current draw to exceed 500mA (max USB).
buddrousa
I think it is a bad design due to leaving the scanner turned on with the volume all the way down so it records at night to only run the battery down while it is plugged up to a charger. I guess I have bought my last $485.00 lemon with no support for a battery problem that I can swap the same set of batteries between my PRO-18 10 plus hours and my PRO-668 4.5 hours and 10 hours with any 3 of the 4 batteries in a bcd436hp so it is not bad batteries. I am at 10 days with out a reply from RS tech support local RS told me there is no tech support all were let go.
Blackswan73
Central Indiana
Not sure why you are getting such poor battery life from the 668. I am using the RS 2500 mah batteries in my 668, and I get round 12-13 hours on mine. Of course, I don't use LED alert, or backlight. That is not bad, but I get 15+ hours from the same batteries in my 1080
