I'm not at all surprised at the PRO-668's battery life, given that a set of 1900mAh Eneloops powers my scanner for 9 hours, while scanning a P25 system and recording every transmission to the SD card. Just like the PSR-800 and WS1080.
Since I have your ear, let me ask you about a couple of things .....
1) At times when the scanner locks on a signal (P25) initially the audio is 'garbled' but clears up. Almost as if it was a weak signal that got stronger. However the signal strength meter indicates full strength. Is this just the scanner 'locking on' to the P25 signal initially. It does not happen all the time, it is random.
2) Here again, randomly the audio of a P25 signal drops out, the signal strength meter on the display indicates a full strength signal ... just a loss of audio. " Dead Air " is a term that comes to mind.
I read about the need for the attenuator in highly RF congested areas, evidently because of front end overload. Even thought I am not in one of those areas, I did turn on the attenuators. This had no effect so I installed an external step attenuator between the antenna and and scanner. Here again no change.
I am not ready to blame the scanner yet as we are investigating an external source of trouble for us causing interference on VHF FM frequencies in the 140 - 160 mhz range.
We are looking at the US Military as the source of trouble in the VHF frequency range because some of that interference showed up when a radar blimp was put in the air over Aberdeen Proving Grounds.
