ngel
My pro-668 computer application is not seeing my scanner no matter what fix. When i go to set the clock to computer time to check communication with the scanner is says scanner can not be found.
1. I have tried updating the driver signing issue- keeps saying driver is up to date.
2. when i plug scanner in the clock turns on like normal and i can see what is on the card in the scanner, and also the scanner begins charging.
3. I reinstalled the application three times without any luck.
4. I am able to use Unitrunker using the same cord and this software work's fine with scanner plugged in
5. I am able to program the scanner, but it will not connect to update.
Anyone have any idea's ? I think i have tried all the solutions recommended on here already
