218beejohn
- Joined
- Mar 28, 2020
- Messages
- 3
Hi folks, hoping for some kindly guidance here....
I've assigned all the conventional channels (26 total) for a statewide agency to a playlist using the iScan software and uploaded it to my scanner. I can enable this playlist on the scanner but it will not play any of the channels in this playlist. The arrow on the display moves to indicate that it's scanning but nothing received.
When I select "Browse Objects" and select this playlist, all the channels I programmed are there. I can select each, one at a time, and they receive traffic just fine. I then go back and select this playlist, select "play" and it just scans forever without stopping on any channels & no traffic received.
This only seems to be a problem with conventional objects on my scanner. Digital objects programmed into my other playlists scan just fine.
I've researched the heck out of it, checked everything I can think of but throwing in the towel. Hoping it's just an obscure setting I may have messed up. Appreciate help from those experienced with this scanner. Thank you.
