Pro-668 Revert firmware from ws-1080
bfaust50
Roseville, Ca
Rather disappointed with the Pro-668. How can I revert from firmware WS-1080 back to the Pro-668 out of the box firmware?
EricCottrell
Boston, Ma
Hello,
You use the GREFwTool. Set both the Scanner Type and Firmware Type to Pro-668. You can download the stock Pro-668 firmware. Put the scanner in CPU Update Mode. Upload the Pro-668 firmware file to the scanner.
73 Eric
trp2525
If you updated your DSP firmware to 3.0, you will also need to roll that back to version 1.3 if you want to fully bring your PRO-668 back to the latest "stock" firmware released by Radio Shack. You can do that by using the Radio Shack iScan program AFTER you convert your radio back to a PRO-668. Go to "Check for DSP Firmware Update" in iScan and load the DSP version 1.3 back into your PRO-668.
