WS1080: Pro 668 upgraded by whistler
919ryder
Richmond, Ca.
Immediately after Whistler factory upgrade, Ican't get my pro 668 to power on or communicate with pc over usb.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Wackyracer
Did you follow the included instructions from Whistler EXACTLY?
919ryder
Richmond, Ca.
Sure did. I also tried two different computers (with ez scan) two different usb cords and cpuu updater. I keep getting "can't communicate with scanner" and "unable to verify scanner is in update mode". No lcd display at all, either plugged in or on batteries.
919ryder
Richmond, Ca.
What operating system on the computer?
Windows 10 on both. I also tried loading the drivers after disabling the "drivers must be signed setting and re booting on both computers
Wackyracer
No display on the lcd is a problem.
TRY this...unplug the scanner, pull the batteries, press and hold the power button for at least 30secs while pressing other buttons, Assuming one of the 2 usb cables are good (and they both could be bad) plug the scanner into USB wall wart and report back if it powers on ,if it doesn't call whistler.
919ryder
Richmond, Ca.
I will try that. Both usb cables are OK when used with my bcd 436, and worked with the unit in question before the upgrade. Thanks.
scannerjunkie
South Suburbs.
Please keep us posted with your diagnosis. i am in the process of sending my 668 for the upgrade and want to know what to look for if i happen to run into this situation.
919ryder
Richmond, Ca.
I tried taking out the batteries and SD card and pressing power and other buttons as the other person who posted suggested, and it came on! Will post again after I mess with it for a bit..
919ryder
Richmond, Ca.
So, the unit appears to be working fine now no problems whatsoever. Works well, even.
Strange. Until that "take the batteries out, unplug, and hold power while pressing other buttons " thing, I thought it was a dead duck. It would appear that the upgrade was a-ok, and I just had a glitch.
