I there any way to get programming for a pro-688
The question has been asked and answered several times, look at these threads. The search box is your friend.I there any way to get programming for a pro-688
It would help if you let us know specifically what agencies you're trying to program so we can see if the Pro 668 is the right tool for the job. Looks like Chester IL is primarily analog so it shouldn't be too complicated to programI there any way to get programming for a pro-688
The easiest way is to send your scanner to Whistler for the Legacy Upgrade. You will be able to use the WS1080 EZ-Scan software for database and firmware updates and programming. It will also improve performance and add DMR. Upgrade Your Pro-18, Pro-668 or PSR-800 ScannerI there any way to get programming for a pro-688
My scanner is showing a code 300 and i can not get it to clear ?It would help if you let us know specifically what agencies you're trying to program so we can see if the Pro 668 is the right tool for the job. Looks like Chester IL is primarily analog so it shouldn't be too complicated to program
Thanks i have 15 scanner i was just like to get it working no big deal thanks for your help .The easiest way is to send your scanner to Whistler for the Legacy Upgrade. You will be able to use the WS1080 EZ-Scan software for database and firmware updates and programming. It will also improve performance and add DMR. Upgrade Your Pro-18, Pro-668 or PSR-800 Scanner
There is no Code 300. Do you mean...My scanner is showing a code 300 and i can not get it to clear ?
03-00 | No MicroSD Card inserted | Ensure that a properly formatted MicroSD card is fully inserted and locked in the MicroSD slot. |
Is there any way to get programming for a pro-688
This may still be the best solution.I've had the legacy upgrade performed on two 668's and they work great!
I tried explaining this twice to the OP to no avail. They haven't been online since the 6th so I'm guessing problem solved or they gave upAll "3-xx" codes are related to the micro sdcard. Make sure it is in the scanner (under the battery door) and it is inserted all the way,
If you decide to get a new one, I'm sure somebody would be interested in taking the 668 off your hands if you posted it in the classifieds.so.....$70 and 4-6 weeks to update this scanner? May as well just buy a new one..
Yup. That would be the plan. Now to find something that I can keep programmed for years to come.If you decide to get a new one, I'm sure somebody would be interested in taking the 668 off your hands if you posted it in the classifieds.
