Pro 89 Scanner
orms
I have a Pro 89 race scanner. I also have a couple of other scanners which I have programs to assist me in programming the scanner. Thanks in advance for the help
Nasby
Ohio
Not sure what you are asking here?
Do you need help programming them?
orms
I Currently have the pro 95,pro 83 and now I have a pro 89. I am using win95 and pro 83 to assist me in programming the scanner. I am curious if there is a program like those that will assist me in programming the 89 or if I need to program it manually
Nasby
Ohio
I don't think there was ever software for the PRO-89.
Look on the side of the scanner to see if there is a port for a programming cable. That would show that it's possible.
ekrub
I have a Pro 89 scanner and program it using ProLink each year for the Indy 500.[1] Since I have a Mac, I run ProLink in a Windows virtual machine using VMWare or VirtualBox.[2] You will need a USB to Serial Adapter.[3] You will also need a cable that goes from serial DB9 to headset jack.[4] I built my own DB9-to-headset cable using parts from Radio Shack (basically DB9 pin 5 to stereo base & DB9 pin 3 to stereo ring), leave it connected to the USB-to-Serial Adapter, and pull it annually to program my Pro 89 from ProLink. Serial settings are 4800, N, 8, 2, no flow control.
Cheers,
-Burke
[1] Popular Software for Radio Shack Scanners - The RadioReference Wiki
[2] https://www.virtualbox.org/
[3] Amazon.com: usb to serial
[4] http://maml.in/1ncCy0F
