PRO-92 help...
spiritwolfpr
San Juan, Puerto Rico
Hello Friends:
I'm programing my PRO-92 by hand. I with some frequencies of
the Puerto Rico State Police in Motorola Type II Smartzone,
it will not scann but if I move in the manual mode I can hear
trnasmicions going on, but as soon I put it in Scanning I can't hear
anything!!
Please Help!! :(
Bentley
Freehold, NJ (Monmouth County)
Is it possible that one of the control channels are locked out? Manually search through all of the channels you have entered for the PR state police and see if any of them are Locked out. Do you have the mode set correctly to MO ?
MacombMonitor
spiritwolfpr said:
Hello friend:
I'll check on that and does open or close have anything to do
with my problem??
Open mode will scan all the available talk groups, even if you didn't program them. Closed mode will only scan the talk groups you have programmed. So until you get things sorted out, try Open mode.
dangitdoug
If PR is a splinter system the 92 will not scan it. I have the same situation with San Diego TRS system. There is an Offset mode on my Pro95 that the 62 does not have. That allows it to scan the city system.
dangitdoug
bravo14 said:
dangitdoug hit on the money. I think from pro95 and up has that feature.
Can I show this to my wife? She says I'm never right.
spiritwolfpr
Hello Friends:
Ok!, in the RR data base I have found some frequencies
and talkgroups. But I don't know what info to input in
the Scanner(PRO-92).
For example:
Policia (Police) De Puerto Rico-Carolina Talkgroup []
DEC HEX MODE DESCRIPTION
400 019 A Ops
432 01b A Dispath
464 01d A Ops
What do I need to put in??
Please Help!! ;(
W4KRR
Coconut Creek
spiritwolfpr said:
Hello Friends:
For example:
400 019 A Ops
432 01b A Dispath
464 01d A Ops
Please Help!! ;(
In your example, you need the first digits in each row, the DEC (Decimal) numbers. 400, 432, 464, etc. You don't need the hex or mode information.
spiritwolfpr
Hello Friends:
W4KRR thanks For the timely help I"ll probably
be back JAJA for more help. Since The PRO-92
is my First trunking scanner and, acording to the wikii it will
survive the rebanding.
Thanks again!! :)
spiritwolfpr
Hello Friends:
FMON thank you for the short cut and I know there is a way to
put your name in the scanner insted of "Welcome to..." does
any one knows?
spiritwolfpr
Hello Friends:
I'm starting to figure my PRO-92 scanner out,
but there has to be an easier way to program it,
by hand it takes for ever!!
BTW can the PRO-92 Overcharge the batteries??;)
W4KRR
Coconut Creek
spiritwolfpr said:
Hello Friends:
Download the Win 92 programming software, it's free here. You just need to buy a programming cable, info is available here.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Moderate protection, but compare the 92 with the 93/95. The 96 is similar to the 95.
