Pro-92 ID Monitoring
texasemt13
CenTex DBA
Hunter, TX
Evidently by tapping the discriminator, manually pausing on a control channel and feeding that information through a serial cable to a program like UniTrunker, the 92 should be able to handle this. However, I do not think the Pro-92 is supported by UniTrunker currently. The Pro-2052 is supported (which I thought was the base version of the Pro-92, but our wiki here: Pro-92 says that this scanner was produced by GRE whereas the Pro-2052 was produced by Uniden as seen here: Pro-2052). So it might not be supported by software currently, which would mean you might be SOL. However, I do not know if any other software supports the 92. But, you would definitely need to tap the discriminator (an article is found here on that mod). Let us know what you figure out.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
How do you monitor a ID in EDAC system using pro-92 thank you
Under my signature is a link to Programming Shortcuts. The 92 is listed. Make sure you program the frequencies in the order listed in database. This order starts with channel number 01. Do not start with channel number 00
For Texas13. The base scanner is Pro-2067 and the best software is Win92, free at Software for RadioShack PRO-series (PRO-92, 93, 95, 96, 97, 99, 163, 164, 106, 197) and GRE PSR-series (PSR-500, 600, 300, 400) scanners
fmon
Eclipse, Virginia
Site 001 Medical Center (Northwest)
01 866.11250 02 866.40000 03 866.72500 04 867.62500 05 866.20000 06 866.60000 07 867.17500 08 868.93750
Site 002 Lions Park (Southeast)
01 866.27500 02 866.67500 03 866.93750 04 867.35000 05 866.36250 06 866.77500 07 866.53750 08 866.91250
Chose one of the sites and program the frequencies as listed. You can program both sites but each site must be in its own bank and remember to start with channel 01 in 01 position in the bank and follow the same numbering used above. All Talkgroup ID's can be used in both banks.
The Programming Shortcuts link will give a step by step procedure for programming any trunking system including how to set the scanner to ED mode and enter frequencies and talkgroup ID's.
Be aware, this system will eventually be rebanded down by 15MHz.
