I have a Motorola Type 2 system(Regina ,Sk, Canada)programmed into my Pro 92. I can not get any ids to lock out. Either when I use the lockput on Scanner or when programming? Any ideas appreciated.
Make sure the scanner is in closed mode (a minus under the bank number and not a plus). You can set open or closed mode by pressing the 'func 2' key combination (if memory serves me correctly).
If you have the manual, it explains how to do it fairly well.
