PRO-93 Software
jwt0001
I picked up a USB cable for the PRO-93 and downloaded WIN-93. However, the scanner seems to only be in CLONE mode. How do you get it out of Clone mode? The software is giving me error messages when I try to read from the scanner. Where am I making my error?
Thanks!
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Thanks!
Clone will normally be on the display when the cable is plugged into the scanner. Don't use scanner buttons with the software. For error message, check in configuration>serial menu for correct com port.
jwt0001
Got it to work finally. I had to go in and fiddle with the COM settings, but it's working properly now. Thanks for the reply!
