Pro-93 owners,
I have been playing with the keypad tricks for a while,
and until now I have not seen any changes exept for a @ sign
instead of the usual +/- sign (band lockout).
So I started observing the effects of the 0 4 keypad trick.
This is what it does (or you do):
After doing the 0 4 keypad trick.
(This is done but pushing 0 then 4 RIGHT after turning the radio ON, when "Welcome to Dual Trunking" displays)
On a trunking CONTROL channel, MO:CNTRL or ED:CTL-xx, in MANUAL mode.
The Signal Strength of the trunking control channel will be displayed. I'm assuming this is signal strength, because the number goes down when I cover the antenna, change position, and remove the antenna.
A 2 digit number will show up just before the @ sign, "overwriting"
the D and L, if they where there in the first place.
Signal strengths of 01, 02 or more are actually 101, 102 etc.
The minimum usable trunk signal strenght is about 10.
The signal strenght does NOT show up in SCAN mode.
For sure this works on the Pro-93, maybe on the Pro-92 or probrably more likely also on the new Pro-95.
I found this feature to be very usefull the see how far I could hear the trunked system.
On a final note, if you intend on playing with the keypad tricks,
make sure you first download your scanner to your computer! Some of them will erase your memory!
Enjoy,
Michael
Enjoy,
Michael
