pro 93
bmannbronco
las vegas
Hello I have a quick question? I have all the frequencies dialed in for henderson nevada but when I hear something interesting and want to track it or trunk it I can't. I am not sure what I am doing wrong. Thanks
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Clark County
What is it exactly you want to hear?
I had a look at all the Trunk Radio systems for Clark Co. and
there are a lot.( Casino's etc.)
If you want to listen to Public Safety,(police,etc.) be sure
you have a Trunk bank set up for EDACS and enter the
frequencies in the precise order they are listed.
Man,your lucky to live in Vegas.
-Mike -
freezin' my a-- off in Canada
als365
Santa Clara, CA
sounds like you are inputing the frequencies for normal FM reception. What you need to do is program those frequencies in trunking mode. If you listen to a trunked system conventionally, you are not going to hear the whole conversation if you hold your scanner on one frequency.
If you don't understand trunking, here's a brief overview.
Example - there are 100 people in a room. Not all 100 people need to use the phone at the same time, so the people that own the room only put 10 phones in the room thinking that no more than 10 people are going to need to use a payphone at the same time. Someone feels the need to speek and picks up the first available phone and then when they're done, someone else uses the phone.
Now to relate it to radio - think of the payphone as a frequency and the people needing to use the payphone as a radio channel. Not all 100 channels in a trunked system are going to be used at the same so they reserve the maximum number of frequencies that may be used at the same time. When someone on channel 1 keys up, they are assigned a frequency to talk on. When they key up again, they may not get the same frequency because someone else on a different channel may have been talking on the frequency the person on channel 1 was using before.
The main reason behind trunking is so an agency with 100 channels doesn't have to reserve 100 frequencies, they can get away with reserving maybe 10-20 frequencies.
As more things are using the radio waves now more than before, available frequencies are becoming very limited and we need to reduce the number of frequencies being used.
This whole message is too long to proof read and i'm tired so i hope there are no errors :)
if this does not answer your question please email me.
RFGUY
Somewhere in Nevada
First of all if you program Henderson P.D. as EDACS you would be wrong since it is on the Clark County Motorola system.
Perhaps, that is the program.
Believe only half of the information you read on this website.
Many here seem to be quite misinformed and don't listen to those who try to help and really know what's happening.
Their loss!!!!!
