KR4BD said:
...I CAN SAY that, my experience is that the Pro-94 is better than a Pro-92 by a long shot on such systems. It is more sensitive, has a faster scan rate and is much easier to manually program.
It needs to be since there is no computer programing for it. That IMHO is the main reason for never having one.
KR4BD (continued) said:
Yes, the Pro-92 has Alpha tagging and some other nice bells and whistles which are missing on the Pro-94, but when it comes down to comparing "real radio, performance specs", the 94 is better, by far. I own both these models, so I can talk from experience.
I will certainly bow to your experience for the sensitivity, audio and general performance benefits of a 94 over a 92 (and by extension the 2057) but some of those "bells and whistles" you dismiss are pretty important, especially if you monitor more than one system.
By the way, both the 92 and 94 (and probably all trunkers) will perform much better when the Radio Shack 800 mHz rubber duck antenna ($15) is used for 800 mHz trunking instead of the "one-size-fits-all" antenna that comes with the radios.
In this, I am in absolute agreement. I own 5 different trunk tracking radios and own 4 of the RS 800 MHz antennas. Hmmm, next time I go to RS, I guess I will have to get another one.
The problem here is that you are comparing two radios, one of which is unavailable in the normal retail chain (the 92). BTW I own 2 92's, and yes they have some problems, especially in the sensitivity area; however, when comparing the 92 with the 95, the 95 is "worlds apart" better on that point. As to whether the 94 is better than the 95 on EDACS systems, I cannot speak from experience as I have only compared the 95 against other GRE built radios on an EDACS system. But the 95 seemed to decode no better or worse than other GRE built scanners on the New Orleans Public Safety System (before they went ProVoice
TO:
blakem445
I hope that this helps some; although, it does not answer your question exactly.
