Just the Facts
Bioniccreeper06 said:
when i scan my programed channels its in hyper so it skips alot of stuff and when i tryed to turn it off by holding down the H/S Button and it dosen't turn it off...Anybody know how to fix this?
I again have the same problem, albeit no solution to this one yet. Although, these facts may help someone help you figure it out, as i have given up on it.
1. Hypersearch and Hyperscan are not the same. They are 2 different features.
2. Hypersearch is used for LIMITED SEARCHS only.
3. Hyperscan is used for scanning programmed frequencies.
4. Hypersearch lets you scan 300 steps/sec in frequency bands of 5Khz only.
So maybe Hyperscan just WONT shut off within certain frequency bands.
turning on priority scanning is the key's secondary function. If you notice, when scanning, if you hit priority / H/S. The scanner will only turn on/off the priority function.
I've been trying to shut off hyperscan in the 800Mhz + 900Mhz range since i bought the scanner.
If you figure it out, please post an answer.
