pro 94 static .
scanfan447
Myrtle Beach SC.
my pro 94 seems to be in squelch mode all of a sudden after a conversation in trunking also all conventional freqs. are just static .i reset the scanner twice and it did not help .can it be fixed or time for a new one lol?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Don't want to sound facetious, but you have turned the Squelch
knob clock-wise , right ? :idea:
That would normally eliminate the hiss or static sound. Play around and see if that corrects it.
Is your antenna connected securely ?
But what the hey it's always time for a new scanner ! :lol:
eyes00only
Denver Colorado
I'm not trying to be jocular, but in trunking the squelch is not relevant.
I have a 94, and have never had your problem. When a radio is almost out of battery power in an EDACS system, it makes a wierd noise when transmitting. Where are you located? I doubt it, but it could be a type of encryption.
Jerry
INDY72
Indianapolis, IN
With apologies:
The squelch setting DOES affect trunking in that it affects the reception of the CC. Trust me on this- ten years of monitoring both EDACS, and Motorola TRS's both close up, and from a distance. On the PRO-94, and 2052, if you don't have the squelch set just right, especially on an EDACS system, it WILL cause problems with locking on the CC. Once the CC is locked, squelch is not important. If your using tight squelch to acqure a distant EDACS CC,.. then yes once it goes back to conventional scanning, you will lock on the first conventional freq and HISS! SO you will need to readjust the squelch for conventional. If your trying to hear the EDACS from a distance, then you really need to lock out the conventional banks and just listen to the TRS. If you really want to hear the conventional, then you will just have to deal with spotty, if a lock at all on the EDACS CC. Motorola systems are much better for distance monitoring, but the same advice applies for them too.
scanfan447
Myrtle Beach SC.
pro 94 static
just like to say thanks for all the help but i believe the problem may be internal. i have had the scanner 4 yrs , may be old age . i keep the squelch fully clockwise while trunking also changed the antenna to see if it would help! maybe wife will let me buy a 246t lol.
VegasCorbin
Las Vegas NV
My Pro-94 is just a few months old and I also get this problem. I thought it was just my unit and the fact that I am useing the original anttenna.
Any addtional thoughts on this?
scanfan447
Myrtle Beach SC.
pro 94 static
my scanner was working well untill a week ago .it goes to squelch after a conversation. also i have lost all conventional freqs .just don`t understand?
any exsperts out there? heeeeelp lol.
LarrySC
Greenville, SC
If you had a NEXTEL direct connect radio near you scanner it could have ZAPed it. My area is NEXTEL HELL. Seems like everybody in a service business has one. The local FOX TV station had me look at their 800MHz scanners that quit working. I found a NEXTEL on the desk in front of the scanners. They were some of the cheaper Uniden types. Long story short. They got new scanners. I programmed them. Installed outside antennas. They now step away from the news desk when using the NEXTELS. Problems solved. May not be your problem but everyone should know this.
scanfan447
Myrtle Beach SC.
pro 94 static
to larry sc do u mean nextel 2 way radio?we use 2 way radios at work but i believe they are motorola .i will check to make sure.thanks for the info.
INDY72
Indianapolis, IN
Yes he means the Nextel Motorola radio.
