Pro 94 trunking help
After reading back to june it looks as if there are a lot of people looking for help with scanner progamming problems but not to many knowledgeable responses. Guess I will add to the list of help seekers. I have a pro-94 trunking scanner with all the freq. in for my location. The manual is no help as the scanner does not respond to the directions in the manual. I am trying to scan a trunked system Motorola type II. was getting voice until I tried to save ID group to a list. Now no voice but it does stop when the channel is busy. Non trunk freq. have voice.
BANDIT
Gainesville, Ga
Check to see if your scanning the bank in open mode or closed mode. If the bank is in closed mode and no ids programed you wont hear anything. When its open there is a + under the bank number, when it is in closed mode for trunking only programed ids there is a - under the bank number. On my Pro95 func 5 toggles the open, closed mode.
No function
The pro 94 does not have a funtion button. This is a mobile scanner with 1000 channels :cry: Thanks for trying.
scanfan447
Myrtle Beach SC.
pro 94 trunking help
your pro 94 should work ok after these steps! you push program than trunk than # of bank you wish to store freqs.push scan button till it beeps twice than push search button till it beeps twice. you should see little straight lines. when a talk group comes up push the mon/clear button to hold the talk group. push prog button than svc button, it should go to list 1.go back to search find another talk group and repeat. i hope this helps!p.s. make sure all freqs are put in bank before you search good luck!
eyes00only
Denver Colorado
In case my PM did not get to you, if you still need help tomorrow, PM me.
PM is a personal message. See the bottom of my post.
It's almost my bedtime.
Jerry
