amusement
- Joined
- Aug 23, 2004
- Messages
- 395
PRO-94 shows "wired" after being turned on.
Here's the list of things I have done:
* Pressed 2 + 9 while turning on the scanner to clear the settings
* Use the PC/IF cable (which works on my PRO-95) to clear "wired"
* * Set serial port to 8, N, 1 and 8, N ,2 with no success
* * * Used demo of Scan lite
* Verified PRO-94 was running at 9.6Kbits by pressing the "4" button
for 2 seconds
Both the cable and serial port are working. I can content my PRO-95 with no
problems.
I disassembled the PRO-94 and located J203 (PC/IF) jack.
J203 has three solder points. Two points are common and one isolated
until a plug is inserted. This results in three common (or shared)
points. Hope that makes sense.
Solder points for PC/IF jack
J203 * common
* switched via plug insert
* common
The tip and ring should be RX (receive) and TX (transmit). But they
are all common electrical points. Which confuses me. The service
manual for the Pro-94 DOES NOT include a reference for
J203 in either the schematics or parts.
I need a schematic that does include the J203 jack and the modem IC.
Any constructive suggestions are very much welcome at this time.
for 2 seconds
problems.
J203 * common
* common
