Pro-95 and EDACS ?
schnit
Could someond tell me please if the pro-95 will scan a EDACS Networked Standard system if freq's are in proper LCN?
johnyvico
yes i have a pro 95 and pro 96 . i scan the south jersey area and philadelphia . what EDACS are u looking to scan maybe i can be a help . u must do the EDACS sytem starting with the 01 channel and the in the LCN order . and make sure u change the the mode to ED and it should work fine .
schnit
Thanks to you both. I am looking to minitor this system >> http://radioreference.com/modules.php?name=TRSDB&sid=1871 site# 115 (Fort Wayne).
Originally, I realized that I didnt have the LCN correct (started at ch. 00), however I have corrected it and still havent heard any traffic on this system yet. This maybe because it is a utility co and there just isnt any traffic right now being that it is Sunday. I keep monitoring and see what happens. Thanks again!!!
Oh, and I do have mode in ED.......
johnyvico
i just saw the freqs that u wanted to minitor and as long as u start in 01 and go in the exact order it should work fine . p.s when u get the freqs in go to the channel 05 in the bank that u are putting that into , and hit manuel it should make the control channel sound and say cntl-05 if not the the control channel is wrong , thanks
nexus
Mississippi
Also make sure you have the Scanner in OPEN mode. There should be a + symbol below the bank you have that trs programmed into..
It'll sit there in the bank and say SCAN Up... And when ever a talkgroup becomes active you'll see the talkgroup ID appear on the display. You can press the Trunk button to store it into the scanner. Just give it some time and you'll eventually hear stuff..
