Pro-95 Bank Tags
schnit
Is it possible to program text tags for a specific Trunked, Group ID bank. I managed to get my individiual group ID's, however the third line still reads "Bank 1 Ch 08" etc. TIA...
enginecompany
yes, press pgm then trunk the ID will appear, then press text and then put in the correct text for that specific talkgroup, hope this helps.
loumaag
Silent Key - Aug 2014
Katy, TX
The third line is the frequency alpha tag. The default is the bank and channel number, which is what you are seeing. Lots of people use the Site ID for those alpha tags on Trunked Systems.
schnit
Already got the individual text tags mastered. My thing is that I want to tag the group ID bank. When my scanner stops on a talkgroup, my scanner displays the data and frequency on the first and second lines, then the third says "Bank 1 Ch 08" or whatever spot the frequency is at, and the forth line is the text tag for the individual TG that I put in. I want to change that third line with some sort of Bank tag, or a sub bank text tag. Possible?
schnit
How can I change it? I've got to be able to make it say something other than that right? There has to be a way for me to individualize that with text, instaed of it just saying "Bank 1 Ch 08".
loumaag
Katy, TX
Okay, I guess we were posting at the same time. There is no ID Bank tag in the radio. So, in answer to your question, no you can't. When scanning a trunked system, and activity happens, the second line is the voice frequency, the third line is the aplpha tag for the control channel. As I said if you change that from the default to the site location you will know what site you are getting the transmission from.
loumaag
Katy, TX
The saem way you change any frequency alpha tag. Don't you tag your conventional type frequencies? Do the same to the trunked.
loumaag
Katy, TX
The same way you change any frequency alpha tag. Don't you tag your conventional type frequencies? Do the same to the trunked.
schnit
I think I get it, if I want to change that third line, I need to hit "text" and put something in when I actually put the frequency in, right?
loumaag
Katy, TX
Yes, that is the way. :D
schnit
PERFECT!!! Exactly what I was looking for!!! Thanks a ton guys, I have had this thing three days and poured over the manual and couldnt figure that out. I have a BC796D and things are much different on that unit. I appreciate all the help!!!
