PRO 95 Control Channel Question
dhendry
I have been trying to monitor the trunking network of a local business which I believe is using a type II system. I got a list of the talk groups from an insider and programed them in with a list of all the known freqs. I have the modes set to MOT and scan through them and I here the audio and the correct talk group shows in the bottom but no control channel it would appear that I only have the voice channels. Some will do the machine gun noise thing but not really start trunking. I have also tried to search the entire range for control channels which I put in a lone bank with all my talk groups to see if this is the one. Any hints would be appreciated.
dhendry
In line 2 where the voice channel usually is the same freq shows on line 3 where the control channel usually is. Sometimes it will hang on a station and flash CNTRL and other talk group ids but won't scan off of them....
mciupa
Canadian DB Admin
Moderator
I'm here a lot
How far away are you from this business? That may be a factor.
When your radio flashes CNTRL, does that imply it is searching for the CC?
"Zero" the squelch and see if it will lock on to the CC.
Good luck
dhendry
Is there a chance that this may be type I or type II hybried. but this would not make since that the talk group are showing up with who they are supposed to be. It just seems that all the channels are control channels.
LarrySC
Greenville, SC
Could it be an LTR system? No controller but ID's show. If MOT II then check each freq, one at a time, for controller data. If it's a MOT I then sometimes 4 out of 5 channels could be controllers. The type of scanner?? Post more info w/ your location. May get better answers. Eager to help.
