Pro-95 EDACS Hell
Apot2
Hello,
I live in Miami Dade County, down in South Florida. Yesterday I just programmed my local fire dept's MedCom freq. into the scanner. Now i put them all in LCN order and closed the bank so I only pick up those MedCom frequencies. I pick up the conversations fine, the problem I face is that at the end of their transmission the radio goes back into scanning but gives me the sound of hell. Its a mix of the beeps, mumbled talking, and that sound that sounds like an 18 wheelers engine. Does anyone know whats wrong?
KE5BCP
Analog Man
Lewisville, Texas
Apot2 said:
Hello,
Make sure that you have each channel AND the bank set to EDACS.
Apot2
jayfurd said:
Apot2 said:
Hello,
Both are good.
mancow
N.E. Kansas
Did you start with channel 0 or 1?
The LCN has to start with channel 1 of the bank.
mancow
Apot2
mancow
I do start with channel 1.
mancow
N.E. Kansas
That's a tough one.
I hear odd data grumbles at the ends of transmissions at times when listening to the KCMO system but it's usually a fraction of a second.
The only thing I could think of is the LCN is somehow wrong or you're in an an area with a weak signal or interference.
I would recheck the LCN programming etc.... a few more times.
mancow
Apot2
mancow said:
That's a tough one.
mancow
Dam, what makes it even more horrible is that when these sounds come out, my scanner will no longer continue to scan the numbers I put in the bank, it just does that engine type-beeping-garbled type sound.
Apot2
mancow said:
That's a tough one.
mancow
Dam, what makes it even more horrible is that when these sounds come out, my scanner will no longer continue to scan the numbers I put in the bank, it just does that engine type-beeping-garbled type sound. I live pretty much in the center of my county and I have tried it in different places with the same result.
