Pro-95 mod to unlock frequencies
CoreyW
Calgary, AB
Hi All,
Recently, there's been someone on eBay who has been hawking some utility of some sort that unlocks the (non-cellular) frequencies on a Pro-95.
Apparently, with this utility you "will have access to scan the full spectrum from 17MHz to 1.3GHz."
Has anyone heard anything about this?
Thanks in advance.
Corey.
Pro-95
Washoe Valley Nevada
Yes, I've heard of this.
Rather than go into politics I strongly recommend you go here to get your previously unavailable frequencies. >>>Click here for WIN95<<<
Oh and aside from the programming cable, it's free. ;)
Colin9690
County 21
APE282018
I HAVE HEARD ABOUT THAT TOO! I LOOK AT EBAY ALMOST EVERY DAY, AND I SAW THAT THING. I THINK IT IS FOR THE PRO-93 AND PRO-95. HE ALSO SAYS THAT IT WILL LET YOU LISTEN TO TELEVISION BROADCASTS, MILITARY, FEDERAL AGENCYS (if they are not encypted of course), AND SOME OTHER STUFF. SOUND PRETTY COOL, BUT MY PRO-93 IS FINE THE WAY IT IS.
COLIN
KE5BCP
Analog Man
Lewisville, Texas
With Don Starr's software that Michael pointed you to, you can make those same .p95 files yourself for free. It's also VERY useful for doing the "func/tune/scan up" procedure where you can scan those out-of-range freqs.
CoreyW
Calgary, AB
Thanks Gents.
I figure y'all just saved me a possible $10. Is it straightforward to get these out-of-range freqs with Win95?
Something I'm also pondering, tho. Why are these freqs not 'regularly' accessible via the keypad?
C.
nd5y
Wichita Falls, TX
CoreyW said:
Thanks Gents.
C.
Because the PRO95 receiver doesn't work well outside of the specified ranges.
Mine is nearly deaf on 225 - 400 and is about usless for mil air.
It doesn't have wide FM so its useless for TV & FM broadcasts.
It receives SW AM stations relatively well from about 17 - 25 MHz
if you have a HF antenna.
Just because you can make the LCD display show all kinds of cool frequencies doesn't mean the receiver has to work on them.
Tom ND5Y
