webley445
I have a Pro 95.
Locally we have a Motorola type II (hybrid?) system (Pinellas Co. FL).
Normally in the past I have always justed entered all listed freqs used in the system into each bank, then the TGID's I want to monitor within that bank. (BTW- I do all my programming by hand, manually)
My question is about using the Auto Channel Programming function.
When this is used do I still need to enter all the freqs within the system as I have done in the past?
Or do I just enter control channel freqs then go into the bank I want and set the offset (i.e.- pgm+trunk+func+"3", set offset (normal)+enter.
No fleet map ever needed in the past (prg + trunk + func+"8"+"15" + enter, for type II).
Hope my post is understandable, not well versed on alot of the radio terminology.
Thanks for any help
you can lend.
Thanks for any help
you can lend.
