Re: Duplicate id's
Altpensacola said:
....only going to see "LocalPD Disp" reported when the SO is giving out registrations, license checks, warrent info, etc.
But are you saying it would still pick up the second agency but only
display it as the first agency (alpha tag)?
I am talking about programming one agency in one bank
several times.
If what you are asking is:
Is there any advantage to putting a talk group ID in several ID scan banks or more than one time in the same ID scan bank?
If that is what you are asking, the answer is
no! In simple terms the radio works this way in trunking mode. It monitors the control channel; when the control channel announces a channel grant to a TG, the radio then checks your preprogrammed ID's to see if you have it programmed, it starts at the first one and goes upward. The first one it finds that is not locked out that matches the announced TG from the channel grant is what it stops on. If you are in OPEN mode, of course it does the same thing, but if you don't have the TG programmed, it just displays the TG ID. So there is no advantage to putting the TG in the radio more than once as it will only find the first one anyway. There may even be (but I am not sure of this) a disadvantage, in that the more you have the radio check, the longer it takes to check them all so in case it was something you weren't interested in, it will take longer to get back to monitoring the CC for valid info.
Altpensacola (continuted) said:
Also any idea if this would also work, or not work on a Pro2052?
I have no idea how the Pro-2052 works as I don't have access to one. :wink:
