PRO 95 question
bake
Just got a new PRO 95, love it. I also have Don Starr's software, like it but I'm not understanding the trunking info. I have the trunking freqs and alpha tags in the 00 to 99 area but I'm unable to install the alpha tags in the trunking area. Fleet Map preset is E1P8 and I see the trunking ID # on my scanner, just unable to get the alpha tags to take.
KE5BCP
Analog Man
Lewisville, Texas
The alpha-tag slots are full of blank spaces. Click on the slot, and then use your keyboards backspace key to go back to the beginning of the slot, then you should be able to type in the alpha-tag.
bake
I gave that a shot. It takes the text, but how do I match the alpha tag with the ID# in the 00-19 area?
Sorry, this trunking thing is new to me.
KE5BCP
Analog Man
Lewisville, Texas
Under the "#" sign you will see 00-19. The alpha-tag corresponds to the ID on the same row. For instance, my 01 is "LPD Dispatch" and 25104 is next to it in the ID column.
bake
You have been the most help I have had yet. Now,, where do I get the number to put in the ID? The numbers I got from a web-site for the Talk Groups for my area were like, PoliceDispatch ID# 309-2, Fire Dispatch ID# 402-4, and so on. The ID numbers wont work.
KE5BCP
Analog Man
Lewisville, Texas
At the top of RadioReference.com, click "RR Database". Next, click on your state, then county. Other sites out there are good, but RR is usually alot more accurate than any, due to it's users constantly upgrading any changes of frequencies or talkgroup IDs.
bake
Thats where I got the first info. I'm confused!!
System Fleetmap
Type B0 B1 B2 B3 B4 B5 B6 B7
Mot A A B B C C D D
TT S1 S1 S2 S2 S3 S3 S4 S4
System Frequencies
Site Description Freqs
001 Primary 855.3375 856.2375 856.4875 857.2375 857.4875 858.4875 859.4875 860.4875
System Talkgroups
Updated in the last 7 days Updated in the last 24 hours
All Talkgroups
Subfleet Description
101-01 Housing Authority
200-01 Pager
300-02 Animal Control Day & night
303-01 City Wide
303-03 DSF Call Comm Low
304-01 Airport Ops
304-02 Airport Manager
306-01 Trails West! (r) Low except 2nd Weekend in August!
307-01 Bus Operations Busy with pickups & deliveries of riders
307-02 Bus Maintenance Day & night
308-01 Building Regulations Day
308-02 Code Enforcement
309-01 Juvenile Officer
309-02 SJ Police F1 Ported to 800 Same as 460.15
400-01 Park Maintenance
400-02 Golf Course
401-01 Water Pollution Control
402-04 SJ Fire F1 Ported to 800 Same as 460.6
407-01 Buchanan Co Hwy East Day
407-03 Buchanan Co Hwy West Day
600-01 Streets dispatch
600-02 Signal Lights
600-03 Traffic
600-04 Sewer Maintenance
600-05 Street Maintenance
600-06 Parking Patrol
600-07 Street Managers
600-08 Street Maintenance 2
DonS
Franktown, CO
fmon said:
Try this p95, I got all but the St Joseph Housing Authority to work but it locks in at 1001-1 instead if 101-01.
Block 1 is size code S1. The radio displays IDs in blocks with size code S1 as:
BFFF-S
where:
B = block
FFF = fleet
S = subfleet
Size code S1 has 7 bits for the Fleet ID, so it requires 3 digits (as opposed to 2 digits for all other size codes). Only one digit is used for the subfleet (while all other size codes use 2 digits).
bake
Thank much to you all. And thank you Don S. for a super program. Just sorry I'm so new at this, I havent figured it out yet. I think I'm pretty smart but my inability to wait and work things out takes over.
eyes00only
Denver Colorado
Jay / under the # column, all I have are 0's & 1's :( .
Jerry
KE5BCP
Analog Man
Lewisville, Texas
No sir, the file you sent me has the alpha-tagging in place, rather than some "binary hoo-ha". I'm not sure why it's doing that on yours. Perhaps Mr. Starr will chime in with a solution, as I've never seen that before.
eyes00only
Denver Colorado
Thanks Jay. It's weird, and may be something I'm doing wrong. I haven't had a lot of time to use the software yet. I think I get Fri off, so I'll try then. Also, I'ii try that "other thing" again on Fri.
Jerry
Al42
Long Island, NY, USA
Jerry
Jerry, I'm guessing this is what yous looks like:
(The first 10 are 0s [0-9], the next 10 are 1s [10-19]).
It should look like this:
Just pull the column wider, like you would in Excel.
