CoreyW
Hi All,
I recently bought a Pro-95 to replace my aging Pro-94. Alpha tags was the main reason for the purchase.
However, I found that after I punched in my '94 freqs into the '95, and running both scanners side-by-side, the '94 picked up WAY more than the '95. Most of my listening is in the aircraft band, and the '94 broke squelch MUCH more often than the '95. I did made sure the squelches were set with a very light trigger on both radios.
On the '95 I'd hear aircraft in-flight easily enough, but never the ground side of the ATC comms. Even with no squelch on the '95 I would never hear the ground side of the comms - just static. No so on the '94 - it would pick up the ground comms.
So I thought I'd switch the antennas between the two scanners (I've got a newer 800mhz duck on the '94) and no difference. And I did play with the '95 ANNUNCIATOR and Recieve Mode (AM/FM) and no difference.
Can anyone enlighten me with the reason for what I'm seeing? Is the '95 just plain less sensitive than my older '94? Or is the '95 not as good in the aircraft band? Is it better at all?
Thanks in Advance!
Corey.
Thanks in Advance!
Corey.
