Pro-95 Troubles
roberto1
San Antonio
OK, I'm still a newby with this radio, but I'm having trouble listening to the trunking frequencies that I've spent hours plugging in. I can hear them if I change them manually, but once I hit the scan button, I don't hear any of them. I know there are "live" frequencies on the air, but unless I punch them up manually, I don't hear them.
Radio Shack is baffled by this query. Can anyone help here?? Thanks in advance.
AZScanner
Somewhere in this room. Right now, you're very col
I'm just guessing here, but is this an EDACS system? If so, the channel order is important. Let us know what system you're trying to monitor.
-AZ
KE5BCP
Analog Man
Lewisville, Texas
In addition to what AZ said, make sure you have both the channels set to MOT or ED as well as the bank set to MOT or ED.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Okay,assuming you have entered your freq's in trunking mode, try
hitting SEARCH you should have talk group ID's appear.
Are you at least seeing
on your display ?
If you are hitting SCAN and your display shows
1 -----
that means your scanner is ready for you to program a talk group for the
first spot in the scan lists
I like to monitor in SEARCH mode as opposed to SCAN as some times
talk groups are "patched" and I don't want to miss anything .
scanfan03
Houston, Texas
on your display ?
1 -----
This is for an RS scanner, not a Uniden. If you don't have any ID's entered in, put the bank in open mode by going to the bank in manual mode and press Func then 5 or Func then 2 ( I get my 92 and 95 mixed up, can't remember which one it is.).
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Good point scanfan03, I was relaying RS info as he mentioned enquiring with Radio Shack about this issue in his original post.
But nevertheless your info will help someone with a Uniden model who
encounters the same problem.
Never know who reads these posts !
loumaag
Silent Key - Aug 2014
Katy, TX
Uhhh, no you weren't. You were relaying Uniden information, useless for a Pro-95. scanfan03 was correct, put the radio in OPEN mode and see what you hear. Of course AZScanner was even more on the money. If we knew what you were trying to listen to, we could be a lot more specific. :D
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I stand corrected. :oops:
I hope my suggestion of SEARCH mode = OPEN mode at least !
loumaag
Katy, TX
:lol: Not really. SEARCH on a Pro-95 (indeed all of the GRE trunk tracking scanners) puts the radio into service search mode. This is where the scanner scans the pre-defined frequencies of different parts of the spectrum. For example, CB, MARINE, POLICE, FIRE, etc. It really doesn't have anything to do with Trunking as there is no place to hold a TG ID so you can't track.
:lol: What you are suffering from is a malady that I also suffer from; excessive radio exposure. Sometimes I can't remember how to tune my HF rig and I only have two of them. :lol:
